Tyre presure
Old Dec 22, 2009 | 11:09 PM
griffon's Avatar
4th Gear
Default Tire pressure
What is the proper or best tire pressure for the front and rear tires on 16" rims? I own a 01 disco.
Old Dec 23, 2009 | 08:21 AM
hilltoppersx's Avatar
depends on what you are driving over
Old Dec 23, 2009 | 01:43 PM
LANDZUII's Avatar
26 psi frt and 41 rear,, OEM spec
I have a ARB and winch and E load tires so I do different psi in mine.
I have found that to much air in the frt tires and the steering gets light and does not track as it should.
Old Dec 23, 2009 | 06:38 PM
antichrist's Avatar
Depends on the tires you have and how much weight you're carrying. Best way is the chalk test. Cover a good section of tread, all the way across the tread, and adjust the pressure until you have an even imprint.
Old Dec 23, 2009 | 08:24 PM
I run 40psi front and rear.
Make sure you check yoiur spare tiere psressure every 6 months, nothing worse than haveing a flat spare when you get a flat tire.
Old Dec 24, 2009 | 07:51 AM
griffon's Avatar
4th Gear
Thanks for your help.
freshdew82
Nov 6, 2012 02:07 PM
4x4trouble
Feb 2, 2012 07:27 PM
franz
Mar 24, 2011 03:46 PM
sforb
Sep 3, 2009 05:11 PM
Disco C
Oct 23, 2008 06:39 PM
