Tyre and wheel size advice
Old Sep 30, 2020 | 11:29 AM
OSOK's Avatar
5th Gear
Originally Posted by DisCody2
I ran 265/65/18's on my 99 DII stock height with no rub. Works out to about a 31.5" tire. Still looked good after I did a 2" spacer lift, but I eventually went to a 32" tire. I never had an issue with TC or ABS performance and I did quite a bit of off road and snow driving, just threw the speedo off a little.
That sounds good as my fear is not going as big as possible and wanting it changed straight away . The 32 inch would be similar to a 275 x 65 x 18 which I would go with assuming it will fit without issues ? Some of the local guys who run D2's have wheel spacers fitted and are saying to skip the 30mm and go for larger such as 40mm or 50mm knowing the look I'm after . A company in Coventry use a German make but are saying £370 for a set which is nearly 4x the price of 30mm's
Old Sep 30, 2020 | 11:38 AM
Discorama's Avatar
Tires that size will rub on the radius arms at full turn without spacers.
Old Sep 30, 2020 | 11:44 AM
OSOK's Avatar
5th Gear
would 30mm spacers or larger eliminate the issue of rubbing on that size tyre ?
Old Sep 30, 2020 | 03:28 PM
merebel's Avatar
I am also going with the 2 inch lift with a 275/65R18 tire. Still need a few more little things to get before I start
jringeno
Apr 23, 2026 05:54 PM
Snafu / Disco Fries
Mar 13, 2015 02:56 PM
Yosemite Sam I am
May 31, 2014 07:49 PM
DonRW2007
Aug 18, 2011 10:36 AM
jaaa
Defender
Oct 3, 2007 04:09 AM
