Engine Swap from 4.0 to 4.6
Old Sep 30, 2020 | 01:45 PM
soarvet's Avatar
Default Engine Swap from 4.0 to 4.6
Okay.. I know this has been covered quite a bit and a few have done it, but I can't find anything. I have an 02 Disco with a Bosch 4.0 engine without the secondary air. Man... it's a dog. I'm just about to flip 260,000 miles. YAY.. I'm never getting rid of this thing, I love it! I've swapped out the transfer case to an 04 transfer case. Now, I think I want to upgrade the engine to the 4.6. Question is... since I don't have secondary air, if I dropped in a 4.6 would I have to add the secondary air or can it be swapped without it. I believe all 4.6's had secondary air.
Is there a noticeable gain in power from the 4.0 to the 4.6? Or would a fresh 4.0 be good enough. I think I'd have to replace the ECU with a 4.6 ecu. Any guidance, thoughts..?...
Old Sep 30, 2020 | 02:20 PM
acg's Avatar
acg
A heads up.... if you go with the 4.6L engine .... you may need to replace the 4HP22 with the 4HP24 to handle the additional torque
Old Sep 30, 2020 | 02:22 PM
whowa004's Avatar
If you have a good block you can swap internals over from a 4.6 into the 4.0 block and just need a 4.6 computer I believe. No issues with SAI from my understanding when going this route. Also a good time to try and swap in a cam and squeeze a few more horses out of the motor.
Old Sep 30, 2020 | 03:59 PM
mollusc's Avatar
Not all 4.6L engines came with SAI. I've worked on a 2003 that didn't have it.
Stu-Nyce
Apr 14, 2016 01:37 PM
badassbmwm3
Nov 17, 2014 09:29 PM
cromartie
May 20, 2014 02:34 PM
mdf27
Feb 15, 2011 06:44 AM
instg8r
Sep 5, 2009 11:19 PM
