u-joint replacement/D2
Old 07-19-2012, 01:09 PM
javven's Avatar
I really try not to jump on the bandwagon calling anyone's stuff 'crap'. I realize it was the shop, etc but you should be 100% objective when it comes to your vehicle and your wallet.
I have, at this point seen I think every single brand there is of U-Joint break on the trail. After they broke... they all looked like crap.
  #22
Old 07-19-2012, 02:53 PM
Joshman's Avatar
Default GB
Does anyone know what parts Great Basin Rovers uses in its rebuilt shafts? Thinking of going this route, and Mike seems to stand by their stuff.
  #23
Old 07-19-2012, 05:01 PM
Bkreutz's Avatar
Why don't you call them and ask?
  #24
Old 09-13-2012, 09:57 PM
NewCityNewRover's Avatar
Just replaced the the u joints on the front drive shaft today. No problem till one of the pin bearings went sideways and jammed everything up. Did my best to fix the problem and everything else went fairly smooth. Quick question as I am fairly new to auto repair, but not new to a tool kit. The front drive shaft went right back in, marked everything so the alignment was the same, tried to stagger the zerks on the end caps, but is there any noise, vibrations, or things I should look for the next couple hundred miles or so? Just want to be sure I did everything right.
  #25
Old 09-14-2012, 05:54 AM
drowssap's Avatar
you should be keeping an eye out for all of those things for the next couple hundred miles, it only wise. Also be sure to grease it with every oil change
  #26
Old 09-14-2012, 11:30 AM
Joshman's Avatar
Would any of you buy a used drive shaft? What if it is an HD from GB or a TW that could be had for under $150? As long as it has been maintained (and even recently rebalanced), shouldn't it be okay? An HD from either brand runs 3x that price, and even the normal duty ones that are fully serviceable cost at least 2x.
geek_IM
07-10-2013 05:09 PM
LRD2&ME
04-19-2011 02:42 PM
AZDISCO
06-15-2008 08:11 PM
humroot
01-04-2008 07:48 PM
RobFrey1
09-22-2005 02:12 AM
Quick Reply: u-joint replacement/D2
