Ugggghhhhh Oil Pump let loose today
Could be as little as burst oil filter or oil cooler line (if equipped) that came apart. Lot of owners are driving around with a cracked oil pump gear, just does not make all the pressure it coul, and sometimes ticks. The oil pump replacement kit is about $115 from AB. Now if it is the front cover cracked, more money; might be able to get one at a junk yard cheap.
A Chevy swap? Really? I'm pretty sure this has been discussed before. If there is any kind of inspection in your state, it can't be done. If the engine can be made to physically fit (i.e. drivetrain adapters, accessory mounts, cooling system, exhaust, etc.) integrating the electronics will be very time consuming. A reman block with top-hat liners would make more sense and ultimately cost less.
If you don't relly need the vehicle and have plenty of time, patience and skill and relly want to show that you can make the swap actually work, then go for it. Otherwise, stick with a Rover engine.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
