Uhg what I mess up
Old 11-28-2021, 05:43 PM
merebel's Avatar
Also any trick to get the torque converter to slide in?
  #42
Old 11-28-2021, 05:52 PM
merebel's Avatar
  #43
Old 11-28-2021, 07:11 PM
Extinct's Avatar
Received 1,509 Likes on 1,069 Posts
Rotate torque converter as you slide it in, much easier to do with shaft vertical. Change the center shaft o-ring on the Tcase while you have it apart. Several threads and videos on that.
  #44
Old 11-28-2021, 07:35 PM
merebel's Avatar
wow stand it up vertically ok scratches head lol
  #45
Old 11-28-2021, 09:19 PM
Extinct's Avatar
Transfer case needs to be off to change the center shaft o-ring anyway. Get a 5 gal bucket, lay a couple 2x4's across the mouth and put the transmission on end with the shaft sticking down in the bucket.
  #46
Old 11-28-2021, 09:23 PM
merebel's Avatar
ha I don’t think of that
milk crate too
  #47
Old 11-30-2021, 07:27 PM
merebel's Avatar
Torque converter in flipping it on end was easier. I had 3 clunks as it dropped in and this is how it looks.
  #48
Old 11-30-2021, 07:37 PM
Extinct's Avatar
Put a little grease on the nose of the converter and on the bellhousing alignment dowels to help is slide in.
  #49
Old 11-30-2021, 07:40 PM
merebel's Avatar
Ok thanks and best way to hold the torque converter in while I transport ?
  #50
Old 12-01-2021, 03:42 AM
Extinct's Avatar
Bolt a 2x4 across the front with some bubblewrap padding between the 2x4 and converter.
JohnZo (12-01-2021)
Quick Reply: Uhg what I mess up
