Uhg what I mess up
Old Nov 28, 2021 | 05:43 PM
  #41
merebel's Avatar
Also any trick to get the torque converter to slide in?
Old Nov 28, 2021 | 05:52 PM
  #42
merebel's Avatar
Old Nov 28, 2021 | 07:11 PM
  #43
Extinct's Avatar
Rotate torque converter as you slide it in, much easier to do with shaft vertical. Change the center shaft o-ring on the Tcase while you have it apart. Several threads and videos on that.
Old Nov 28, 2021 | 07:35 PM
  #44
merebel's Avatar
wow stand it up vertically ok scratches head lol
Old Nov 28, 2021 | 09:19 PM
  #45
Extinct's Avatar
Transfer case needs to be off to change the center shaft o-ring anyway. Get a 5 gal bucket, lay a couple 2x4's across the mouth and put the transmission on end with the shaft sticking down in the bucket.
Old Nov 28, 2021 | 09:23 PM
  #46
merebel's Avatar
ha I don’t think of that
milk crate too
Old Nov 30, 2021 | 07:27 PM
  #47
merebel's Avatar
Torque converter in flipping it on end was easier. I had 3 clunks as it dropped in and this is how it looks.
Old Nov 30, 2021 | 07:37 PM
  #48
Extinct's Avatar
Put a little grease on the nose of the converter and on the bellhousing alignment dowels to help is slide in.
Old Nov 30, 2021 | 07:40 PM
  #49
merebel's Avatar
Ok thanks and best way to hold the torque converter in while I transport ?
Old Dec 1, 2021 | 03:42 AM
  #50
Extinct's Avatar
Bolt a 2x4 across the front with some bubblewrap padding between the 2x4 and converter.
