Ultra Gauge
Old 01-17-2012, 10:54 AM
FightOnUSC79's Avatar
Default Ultra Gauge
Ordered one and it should be here tomorrow, so i wanted a heads up on anything I should be aware of during setup or tweaks i should make.
Thanks in advance
Old 01-17-2012, 11:12 AM
Enjoy, don't worry about mpg, and don't get excited over coolant temps until you have become familiar with the truck's nature. You are shifting from a gauge that is programmed to make casual owners calm, to a digital degree display with very little time lag. And you are monitoring the effect of a mechanical device with a wax pellet that melts and re-cools to operate. There will be some variation on startup. If you can display volts that will keep an eye on the alternator and battery.
Old 01-17-2012, 04:24 PM
G Reeves's Avatar
Thanks in advance
SWMBO calls it my panic gauge as I just have mine set for Engine Temp, MPG, oil miles and a few other on a single screen as i did not want it rotating through loads of screens showing info that i dont care about
Old 01-17-2012, 10:51 PM
Thanks for the tips and suggestions. Now to decide where to put the darn thing? Should be Here tomorrow by the time I return form work, so I'm sure I'll have had a panic attack or two by dinner from watching the display.
Old 01-21-2012, 12:41 PM
Installed and working like a champ. Coolant level parks at 203 and holds steady, so I'm happy with that.
Thanks again
Old 01-21-2012, 01:03 PM
Where did you put it?
Mine is on the windshield just right of the instrument cluster.
Its easy to see without taking your eyes off the road.
Old 01-21-2012, 01:33 PM
Just left of the console in the corner between the cluster and pillar. I'm trying to figure out what info I want displayed.
Old 01-21-2012, 02:05 PM
That is a very good idea for the location.
I might move mine there.
Old 01-21-2012, 02:13 PM
Heres a picture of it mounted. Nice and out of the way then i ran the wire down through the molding for the dash and then brought it back out just enough to slide in to the port. No wires exposed anywhere.
Old 01-21-2012, 03:03 PM
I'm going to buy a shorter mount and move mine in the spring.
Wal-Mart sells the exact same mount that came with the unit, infact my phone mount is what is holding my Ultra-Gauge and the mount that came with the unit is still in the box.
Quick Reply: Ultra Gauge
