Ultra-gauge keeps giving me a code
Old Nov 1, 2012 | 07:49 PM
ashtray's Avatar
Default Ultra-gauge keeps giving me a code
PO134 is the code. This is what I've found it means by searching
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
It shows up as a pending code. What does that mean and how do I fix it? Is it basically saying that my o2 sensors are out?
Old Nov 1, 2012 | 08:03 PM
honda50r's Avatar
Your check engine light has two different "settings." Once your truck senses a problem it examines the particular problem more thoroughly as to prevent the light coming on often. These pending codes occur without a check engine light as you know, but after a few drive cycles and it confirms your O2 sensor is going out it activates the light and turns into a "Trouble Code." This is where it gets especially annoying, because on start-up it does two annoying beeps, the "pending" and "trouble" code warnings.
Old Nov 1, 2012 | 08:06 PM
ashtray's Avatar
Okay so I know what to expect and how it works. How about solving this? Should I replace all o2 sensors?
Old Nov 1, 2012 | 08:43 PM
Maybe checked connections first... see attached, that code is from continuity test performed by the ECU.
File Type: pdf
Old Nov 1, 2012 | 09:02 PM
coors's Avatar
My Ultra Gauge threw me a P0420 "pending" code the other day. I just ignored it. All four o2's are brand new along with new catalytic converters. Not sure why the alarm went off. But its been fine since.
Unless it logs as a check enginr light dont sweat it. Sometimes the Ultra Gauge does more than good.
Old Nov 1, 2012 | 09:23 PM
Before you replace anything watch your O2's on the U-G and see what they are doing.
The supposed dead one will just sit at one voltage or move around very slowly.
I have all alarms turned off, with them on the thing sounds like the cockpit of a fighter jet thats about to slam into a mountain.
Old Nov 1, 2012 | 09:24 PM
bballjames's Avatar
Put some dielectric grease on the connectors. Make sure they are connected tight. Also clean them off. If this doesn't solve your problem, get new 02s. I just went through this about a month ago. I kept getting the same code and then the engine starting running a little rough. Once replaced, everything was back to running smooth and I got better gas mileage. Replace the pair if you do end replacing them.
Old Nov 1, 2012 | 09:55 PM
lr2001silver's Avatar
Banned
I would agree with james and spike here could be dirty connection and if dead your ug will provide the info if you monitor you o2 sensors. The ug does not just beep for no reason it beeps to notify you of a problem and that is the reason you bought it right? When it reports a problem you simply go to the search bar at top of page and type in the code. 1 look 2 read 3 learn 4 make necessary repairs clear code and move on.
thegoat
Feb 9, 2014 01:15 PM
Rover_Hokie
Feb 2, 2014 03:52 PM
01d2Jeff
Nov 19, 2011 10:52 AM
Spike555
ROAMING WITH FRIENDS
41
Oct 24, 2011 06:26 PM
ljdiscovery
Aug 2, 2009 05:46 PM
