Ultra Guage Temps ok?
Old Oct 17, 2012 | 12:33 PM
coors's Avatar
Originally Posted by bballjames
Haha ya that might be true that your radiator is slightly clogged, until your temps get too hot, it doesn't really matter. Put the new thermo in and enjoy your new running temps which should be below 200 all the time.
The good things is that my temps at the moment aren't high. They're right on par w/ everyone elses. 194°-197° highway and 202°-206° at idle on a 90° day. I bought the stat because I want the lower than normal operating temps achievable w/ the soft spring 180°
stat.
I'll address the radiator if and when it becomes a problem. In the meantime, if I can get my 175k mile engine down a few degrees I'm sure she'll be a happier little Brit.
Old Oct 17, 2012 | 01:16 PM
Antmen's Avatar
Originally Posted by mx468
Just wanted to see if 200-208 engine temp was normal for my disco 2. Got these temp readouts while driving around town. Stop & go.
That's normal. If you do a lot of stops locally (ex., store to store, etc.) then sometimes it could be higher when you first start her up and then rather quickly come back down. Mine has spiked as high as 215.6 after a few short stops, but even while idling will quickly come back down.
The UG can make you paranoid. Set your alarms and forget it.
-Anthony
Old Oct 17, 2012 | 03:11 PM
lr2001silver's Avatar
Banned
Not trying to scare you a bit, just know these are 100,000 radiators and they do tend to clog easy and changing the factory radiator at 100,000 is a good idea and a good piece of mind. A 180 soft spring is a great stat and will help cool your engine but may also hide the beginning signs if a clogging radiator. Just my experience.
Old Oct 19, 2012 | 03:04 PM
mx468's Avatar
Originally Posted by ebg18t
Not bad around town. What are your hwy temps?
194 - 198, the lowest was 190 than it shot up to 194/195. This is going around 55-65 mph
Fitzy250
Jul 19, 2018 01:44 PM
DiscoRover007
Jan 3, 2013 10:12 PM
mx468
Nov 26, 2012 01:42 PM
drdeadchef
Aug 22, 2012 08:50 PM
