Ultragauge fuel pressure reading
Old Oct 11, 2016 | 09:24 PM
Frank4's Avatar
Default Ultragauge fuel pressure reading
I saw the fuel pressure option in the instructions but must be missing it when I scroll through the selections when setting up a custom page. Am I missing something?
Old Oct 11, 2016 | 10:52 PM
velija's Avatar
Great I'd like to hear about it too
For me on the initial hook up it would ask how big the tank is
But when I tried to set it up to read the correct fuel amount it would delay not sense/sensor found
Old Oct 12, 2016 | 08:01 AM
Frank4's Avatar
There might not be a sensor for fuel pressure. Only thing I can think of.
Old Oct 12, 2016 | 10:12 AM
mln01's Avatar
Like many other data items UltraGauge can display a lot of things but only if the vehicle computer monitors and reports the data. That's the case here; the DII ECM doesn't have fuel pressure data available.
There is a gauge "estimator" at the UG web site. Enter the year, make and model and it spits out a list of available gauges.
Note: The estimator says UG can display fuel level on a DII. That's a bit false. It doesn't read fuel level directly. You tell it when the tank is filled or partially filled and UG displays a declining fuel level, and distance-to-empty, based on how much fuel is used. A bit crude, I think, but maybe better than nothing.
UltraGauge OBDII Vehicle Gauge Availability Estimator
Old Oct 12, 2016 | 11:25 AM
Frank4's Avatar
Understood. Realtime readings are what I find more helpful. I have coolant temp, intake temp, voltage, mph ( because of larger tires) and RPM. I was thinking about MAF and and O2's but not sure which ones out of the many MAF/02 selections are most helpful.
Old Oct 12, 2016 | 04:46 PM
mln01's Avatar
I have one page with Bank 1 and Bank 2 short and long term fuel trims in the four positions on the lower half of the page. Helpful for peace of mind and very helpful when things are going haywire with the O2s.
jalodge
Aug 10, 2016 12:28 PM
mule2ears
Nov 16, 2015 07:43 AM
robert.juric
Oct 23, 2015 08:42 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
