Ultragauge install question
Old Oct 16, 2013 | 11:43 PM
Eldonkey's Avatar
Default Ultragauge install question
Hi folks,
A quick question(s) about Ultraguage..
1. Is this a simple "plug and play" device that you can pop in and out of any DII with minimal programming or setup?
2. If so, is it adviseable to bring one of these along whenever test driving a DII prior to purchase?
3. Is the main concern the engine Temp read out? 200 or less is acceptable depending if driving or idle, right?
Thanks,
Frank
Old Oct 17, 2013 | 12:32 AM
TRIARII's Avatar
Yes you plug it into the obd2 port and wait afew moments for it to load up. It will ask you to into engine liter size and fuel tank liter size. Only takes about 5 minutes or less to fully install. Bringing it with you is a good idea because not only can you check the engine temp but also see any check engine codes AND any pending codes.
My truck idels at 217 with original thermostat and old cooling hoses and a full load in the rear. I have 133k on my Disco. Id say anything under 212 should be OKAY. Sometimes the temp may fluctuate and it varies from truck to truck. While your there check the engine bay and under the truck for any signs of coolant leaks or burnt oil.
Old Oct 17, 2013 | 02:03 PM
Eldonkey's Avatar
I see.. Look like that's what I'll be getting pre purchase.. Thx!
Old Oct 18, 2013 | 08:41 AM
mattmo78's Avatar
It is very easy to set up and install. The UG is definitely worth the money! It would be great to have on a test drive. Also, the UG works with almost any newer vehicle with an OBD2 port. So, if you don't use it on a LR, you can use it in another vehicle.
Snafu / Disco Fries
Jan 25, 2013 09:43 PM
discoguy96
Nov 11, 2012 07:12 PM
discoguy96
Nov 10, 2012 04:07 PM
anbran
Sep 14, 2012 10:07 AM
slanginsanjuan
Mar 9, 2012 03:55 PM
