Under engine cover leak
Old Apr 22, 2018 | 09:18 PM
redwhitekat's Avatar
Default Under engine cover leak
I noticed a little leak coming from a round plate with 3 bolts just behind the engine oil drain
what is this cover ? It's about 3 inches in diameter with 3 8mm bolts holding it ?
Old Apr 22, 2018 | 10:25 PM
Twix's Avatar
Pics really help, but I believe you're talking about the inspection port for the flex plate. If there's engine oil there, it's your rear main seal, common. Not a fun fix.
Old Apr 22, 2018 | 10:47 PM
OverRover's Avatar
Probably the round Torque Converter plate in the bottom of bell housing.
IF it's leaking oil it can be a bad rear main seal and/or one of the 2 oil ports, or the camshaft cover (lives between the 2 oil ports).
Either way lots-o effort to fix. Good Luck!
Old Apr 22, 2018 | 11:46 PM
No Doubt's Avatar
I covered my camshaft cover (can you cover a cover??) with JB Weld because I did not want to have to pull my motor again...to fix that sort of leak in there.
Ugggh. Not fun.
Old Apr 23, 2018 | 01:25 AM
No Doubt's Avatar
Maybe try something like this on your phone to get a close up look of the problem in there??
https://www.ebay.com/itm/3-in-1-USB-...QAAOSw7WJawznk
Old Apr 23, 2018 | 05:17 AM
Yup overover has the right pic thanks guys for the info
Old Apr 23, 2018 | 09:44 AM
Sixpack577's Avatar
Can be crucifix seals too, they fit in each side of the rear main cap.
Old Apr 23, 2018 | 12:37 PM
No Doubt's Avatar
Those you can fix without dropping the transmission or pulling the motor!
Old Apr 23, 2018 | 01:17 PM
Sixpack577's Avatar
Yep
shame rear main seal is one piece
bfamous
Mar 17, 2014 04:16 PM
san988
Nov 23, 2013 11:36 AM
rezzrover
May 7, 2013 06:02 PM
tmtegt
Mar 20, 2013 07:31 AM
