Under Hood Squielling
Old Aug 21, 2007 | 08:47 PM
Dino76's Avatar
Default Under Hood Squielling
I have this nasty squeeking coming from under my hood. It is when you apply throttle. When it is idling or you are offof the throttleAt first I thought it was a bad belt. As a result I replaced the belt. Didn't go away. Next Thought was a bad pully. I replaced both idler pullies as well as the the tensioner pully. The noise is still there. Any thoughts?
Old Aug 21, 2007 | 09:06 PM
Default RE: Under Hood Squielling
Year and model, how many miles on the truck?
Need to look at your alternator bearings as well as the a/c.
Old Aug 22, 2007 | 09:36 AM
Dino76's Avatar
99 Disco 2. I know there is a problem with the AC bacause when I turn it on I get noise. I am currently waiting for a new compressor to arive. Should be here today. After that is on I will look into the altenator bearing. Can you buy juust the bearing or do you have to buy the whole thing.
Old Aug 22, 2007 | 10:02 AM
Hey, you are driving a Rover, no bearings only. If you look around you may find a good shop to rebuild your alternator, I like doing that better then buying a reman or new one.
Alex_M
Sep 7, 2024 05:21 PM
steveo2000
Sep 8, 2015 08:00 AM
whiteROVER98
Aug 4, 2007 05:09 PM
drhunter
Apr 19, 2007 11:13 AM
rebooTT
Nov 13, 2006 10:04 PM
