Uneven throttle response
Old Dec 30, 2008 | 05:26 PM
sosico's Avatar
4wd High
Default Uneven throttle response
Hi,
I just posted that I have problems with gear shifting but I think is has to do with the engine. When I push the gas pedal on neutral, and I increase the RPM the RPM are not stable, you can hear the engine that goes down and then up again, what could be happening??
Thanks!
Old Dec 30, 2008 | 05:42 PM
sosico's Avatar
4wd High
Default RE: Uneven throttle response
Could it be the Alternator or the TPS? What do you guys recommend I check , and how do I check it myself if possible? what tests can I do?
Old Dec 30, 2008 | 06:19 PM
Is your check engine light on?
Old Dec 31, 2008 | 10:24 AM
sosico's Avatar
4wd High
No, there is no light on. Just the problem. And this morning I realized that when the Discovery is cold it doesn't do it, it is when it warms up? Does it make sense?
Old Dec 31, 2008 | 12:22 PM
What year, model and mileage?
When was it last tuned?
What have you done to check it so far?
Old Dec 31, 2008 | 01:28 PM
sosico's Avatar
4wd High
Year 2002
Model Discovery II
Mileage 42000 miles
No, it has not be tuned.
When the battery discharged, I sent them to check it and they told me the alternator was failing. It has been at least one and a half month and I have not done anything since.
The main problem I'm having is that when I'm driving, it shifts gears like crazy sometimes, downshift gears and then goes up again.
To troubleshoot it had put the Disco, in N, (automatic transmission) and throttle and I saw that the throthling is uneven, and it gets worse when I throttle up to 2000 rpm. It goes down and then up, stabilizes for 5-10 seconds, then it goes down to 1800 and goes up inmediately again.
Any thoughts??
Old Dec 31, 2008 | 03:40 PM
Was was the tranny last serviced, when was the fluid level last checked? If it is OK then you should have a tranny shop, not the dealer, scan the system, if nothing wrong with the tranny then have them reset the adaptive memory and let it relearn how to shift, takes about an hour of your time.
Old Dec 31, 2008 | 06:39 PM
ORIGINAL: sosico
Year 2002
Model Discovery II
Mileage 42000 miles
Theres your problem, you have done nothing.
I replied to your other post as well, have your mechanic check the chargine system and fix what needs to be fixed.
Old Jan 6, 2009 | 08:52 PM
sosico's Avatar
4wd High
I sent the LR to the mechanic, they checked the tranny fluid, they told me it was correct. They could not find the problem, they told me that they used the computer and they found no error codes. Afterwards I bought another alternator, it was replaced today, and the battery was checked. The LR has the same problem. I'm suspecting it is something related with the engine or the valves? It is an intermitten problem, it works fine for a while and then the engine starts acting up, like losing power for a couple of seconds and then coming back. This happens also when I'm on neutral, I push the gas pedal and when on 2000 rpm the engine goes down to 1800rpm and then to 1500rpm....
somebody please help me resolve this.
ps: I also changed the spark plugs and the spark plugs cables.
amytre75
Freelander
Jun 27, 2013 11:43 AM
DiscoRom
Jan 19, 2009 12:03 PM
malmberg
Dec 16, 2008 06:37 PM
azeri
Sep 27, 2006 10:22 PM
Prepilot_3ck
Apr 1, 2006 10:35 AM
