Unheated or heated oxygen sensors
Old Jun 16, 2009 | 09:35 PM
sammyonrye's Avatar
4th Gear
Default Unheated or heated oxygen sensors
I received 4 O2 sensors but they were unheated. In the repair manual, it only talks about heated sensors. When I ordered the sensors, it did not say anything about unheated. Does it matter if they are unheated? I have already replaced the plugs and wires. Here in Oregon, by law, the parts store cannot clear codes. The first time I hooked up the OBDII reader, it gave a code of PO135 and PO134. Any help would be greatly appreciated.
Old Jun 16, 2009 | 09:57 PM
lipadj46's Avatar
P0135, PO134 means you have a dead front drivers side O2 sensor. If you bought an O2 sensor for a Disco I assume it is the correct kind. Where did you buy them from?
Rent or buy a scanner and clear the codes when you are done.
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
topel98
Nov 18, 2007 06:48 PM
adowgiert
Feb 2, 2007 09:11 PM
riebs
Aug 21, 2006 11:48 AM
