Unlabeled switch has electrical connection?
Old May 25, 2020 | 02:00 PM
keninnc's Avatar
Default Unlabeled switch has electrical connection?
Does anyone know why the lower left hand side switch would have connection. I assumed it would be light the lower right side and be a blank.
My D2 is a 2003 SE7. No ACE and no rear air suspension. Left hand drive North American
Picture is attached.
Thanks for any information. I was planning to put a switch from a salvage yard D2 there to run an accessory but did not want to create an issue by unplugging the connection that is there now.
Thanks,
unlabeled switch but has electrical connection
Old May 25, 2020 | 02:05 PM
Best4x4's Avatar
Optional Park Distance Control that was standard on the HSE and optional on the S/SE
Old May 25, 2020 | 02:43 PM
keninnc's Avatar
Thanks,
I guess there is really only one way to find out if it causes an issue by unplugging it. I'm assuming the BCU knows my D2 does not have the feature and therefore the wiring is just there and doing nothing.
Old May 25, 2020 | 04:26 PM
Best4x4's Avatar
That is a blank plate it's just sitting in to hold it into position. Once removed you can just let that connection sit behind it tucked out of the way.
Jeff Blake
Mar 13, 2019 09:10 PM
KingKoopa
May 5, 2017 12:22 PM
azsparrow
Aug 23, 2016 12:28 PM
ktm_525
Sep 4, 2012 10:43 AM
chad420
Oct 26, 2009 03:50 PM
