Unlock does not work on Remote
My unlock button has decided to no longer work. The lock button works fine, but when I push the land rover symbol... nothing. Is this a problem with the battery in the key? Is the button itself causing the issue? Any advice on this issue would be great. I feel like its not the battery because the lock works perfectly... but i dont know...
Thanks for any help!
I just fixed mine. It was completely DOA. Note: don't do this unless it's a last resort. I took out the little circuit board from the FOB. I removed the battery and doused the circuit board with contact cleaner making sure that I doused the pressure switches on the circuit board. I let it dry for a couple days (outside the FOB). It was still intermittent but the switches were clicking again. My last step was to press down the large chip between my thumb and forefinger. This reseated the chip or battery and now it works great.
Mind you any of these steps could also break your circuit board so use it as a last attempt before buying a new one.
richierichrover
05-27-2009 09:42 PM
