Upper Oil cooler hose leak at connection
Old Jun 25, 2012 | 11:58 PM
BoJangles's Avatar
4th Gear
Originally Posted by Brian Mello
If its not too late, the upper "oil cooler" line does have an O ring in it, and the 3 metal tabs inside the snap on fitting will "click" on, when you slide it it. Make sure you slide it in all the way otherwise it will just blow off when driving under pressure. It must be on securely.
Brian could you tell me where the O ring actually goes on the hose? thanks
Old Apr 21, 2014 | 03:12 AM
amit1's Avatar
Is the new pipe solved the problem?
Rufflyer
Mar 22, 2015 10:13 AM
Beaulim
May 2, 2014 08:03 PM
kdscott100
Aug 18, 2013 08:59 PM
wheelgarage
Dec 29, 2012 01:50 PM
javven
Jul 15, 2012 10:09 AM
