Upper Radiator t-pipe question
Old Oct 11, 2012 | 06:02 PM
primussucks's Avatar
Question Upper Radiator t-pipe question
I noticed a crack in the t-pipe today, and also some tracks of coolant sprayed out towards my battery box.
I'm suspecting that this coolant is the source of my squealing belt. I replaced the bearing in the 80mm pulley, and fully replaced the 70mm pulley.
Then I noticed the crack.
I'm wondering if anyone has just replaced that t-pipe with something from a plumbing supply store, like a copper one? then maybe just tap a hole in the top to mimic the plastic bleed screw. Seems like it would be a lot stronger.
Would it heat up too much and melt the rubber hose? I doubt it, but thought i'd ask.
If someone has done this, what size T did you use?
Thanks.
Old Oct 11, 2012 | 06:05 PM
see https://landroverforums.com/forum/di...tem-tee-53416/ for a solution posted earlier today.
Old Oct 11, 2012 | 08:56 PM
0304Disco's Avatar
I have two extras and you are welcome to have one. Let me know how I can ship it to you at your cost of course and it's yours. PM me if you love
kdscott100
Aug 18, 2013 08:59 PM
Selvol
Nov 12, 2012 05:18 AM
Chrisinhouston
Dec 23, 2007 10:26 AM
