Upper radiator tee fitting disintegrates?
#31
I am looking at the brass tee that has a square body, so as to tap for bleed valve and tap for pillar mounted temp gauge and oil pressure gauge. I also like the idea of heater hose shut-off, but not at the expense of no thermostat or tee. Something like this:
Attachment 28996
with this tapped into the flat side:
Attachment 28997
Attachment 28996
Attachment 28997
#33
#34
#35
And the Homedepot part when not using a thermostat, nor tee :
----> Heater Hose Shut-off For Summer Photo by Innernet | Photobucket
I'm just scared to do that since one of the signs my coolant is low is the water fall sound around there. I like to hear that once in a while. Only if the land rover does not leak at all. They leak everywhere, that is why my coolant always look new because I just kept adding coolant, same with oil. We need to design something that you can change the oil filter without draining the oil since I add oil everytime because of leaks. My oil still looks new when oil change is needed except the filter. LOL!
#36
#37
#39
#40
Bleed Valve
Heres a good looking bleed valve with specs.
Item # 1584, 1584 Hand Operated Separator Drain or Bleed Valve On Aqua Environment Co., Inc.
$22.00
These combination might work, these could be a better replacement to the entire plastic Tee.
$22.00
