vac hoses
Old Jun 9, 2009 | 09:08 PM
tweakrover's Avatar
Default vac hoses
i found a vac line fallen off the back of my stepper motor and decided to give the hoses a once over, my cruise control isn't working so i figured there might be one loose there. i found one but don't know where to connect it. the hose comes from the cruise "thingy" (for lack of a better technical term) to a tee which goes into the firewall one way,and the other one goes forward around the airbox and was laying down almost under the headlight by the airbag sensor i can't figure where it should connect unless there is a cruise control component there i can't see. thanks for the help.
Old Jun 10, 2009 | 06:55 AM
kenk's Avatar
Yes there is, and someone correct me if I'm wrong, but there is a vacuum pump under there as the cruise does not run off engine vacuum. Never had to mess with mine so no idea how to get to it.
Old Jun 10, 2009 | 04:50 PM
tweakrover's Avatar
thanks, i looked closer in my haynes manual and it says there is a vac pump under the airbox
grandkodiak
Mar 10, 2011 08:11 PM
kman3786
May 25, 2010 09:26 PM
BUXTONIONS
Oct 6, 2009 06:43 AM
benflynn
Dec 26, 2007 12:55 AM
mach1al
Jun 20, 2005 08:23 PM
