Vacuum hose sizes? (or kit..?)
Old Jan 22, 2020 | 10:22 AM
RA021226's Avatar
Guest
Default Vacuum hose sizes? (or kit..?)
Did a search but found nothing on point: looking to replace all of the vacuum hoses on my '04 D2. Can anyone tell me the different sizes (ID) of the needed hoses? If you happen to know how many feet of each (roughly is fine) that would be great info to have as well.
Alternatively, does anyone know of a vendor who sells an overhaul kit that includes all of the needed hoses and fittings? thanks, mike
Old Jan 22, 2020 | 11:59 AM
XRAD's Avatar
for the evap lines/purge valve? Those are mostly hard plastic tubes and not easy to get to, and stiff so they don't collapse under vacc. Guessing at least 20 feet. I used 3/8th fuel line for the purge valve fitting. This size also fits the small diameter water lines......
Not sure of cruise control line size......
Old Jan 22, 2020 | 01:49 PM
Richard Gallant's Avatar
Old Jan 22, 2020 | 05:47 PM
Tony Luna's Avatar
If you are referring to the small vacuum hoses and nipples for the purge valve / SAI system, I picked up a complete new set from Rovers North for $65.
DiscoRom
Mar 13, 2021 11:35 AM
Chrisw7562
Jan 16, 2017 10:24 AM
Speran
Oct 15, 2015 12:23 PM
slabrat
Apr 29, 2013 09:59 AM
alanroberts50
Aug 23, 2009 03:44 PM
