Vacuum Leak or not?
Old May 31, 2009 | 02:20 PM
alanroberts50's Avatar
Default Vacuum Leak or not?
So I replaced the stepper motor (due to a high idle) with no effect so I was thinking maybe vac leak but in the past when I have found a vacuum leak the cruise control had been affected as well (not operating). This time the cruise is fully functional so could i still have a vac leak or is it something different?
Thanks all
Alan
Old May 31, 2009 | 02:29 PM
jkid's Avatar
Sticking throttle cables or a problem with the cables? How high is it? Might as well check the vacuum.
Old May 31, 2009 | 02:34 PM
khuds308's Avatar
yes what jkid said. or maybe it came out of adjustment. check you all your vacc. lines and make sure they are tight and/or connected. you can use a can of spray on the hoses and listen for change a idle as well.
WaltNYC
Jul 27, 2015 02:24 PM
kevinocall
Aug 30, 2012 12:13 PM
Switzer
Aug 13, 2009 04:23 AM
kfox77
Jul 23, 2009 11:11 AM
mr_boondoggle
Jan 19, 2009 02:15 PM
