Vacuum line
I have some vacuum leak, at least the codes indicate, after I replaced the MAF. If anyone is interested, is the cheap Ebay one, works so far, although I did not expect much. https://www.ebay.com/itm/Mass-Air-Fl...72.m2749.l2649
I thought I read about someone found a set of generic, vacuum hose on Amazon to replace everything. Does anyone know what size that is? I figure it cant hurt. I am going to try a smoke test later with the pump and cigar method.
@redrover75 ... the brake vacuum line is 9mm and I think (?) the SAI tubes are 3mm.
That is a nice kit.
WMYCONGCONG 155 PCS Spring Clips... https://www.amazon.com/dp/B078GCPMQH...p_mob_ap_share
Ben Matheson
04-11-2019 10:47 AM
