Vacuum line
Old Apr 23, 2020 | 09:27 AM
redrover75's Avatar
Default Vacuum line
I have some vacuum leak, at least the codes indicate, after I replaced the MAF. If anyone is interested, is the cheap Ebay one, works so far, although I did not expect much. https://www.ebay.com/itm/Mass-Air-Fl...72.m2749.l2649
I thought I read about someone found a set of generic, vacuum hose on Amazon to replace everything. Does anyone know what size that is? I figure it cant hurt. I am going to try a smoke test later with the pump and cigar method.
Old Apr 23, 2020 | 04:39 PM
XRAD's Avatar
14.95$! I'm impressed. Do a followup to see if it throws codes after some miles...
Old Apr 28, 2020 | 09:41 AM
cvhyatt's Avatar
I was looking at doing something similar but found that all I had to do was add spring clips to the ends of my existing vacuum tubes and my p0441 error went away.
WMYCONGCONG 155 PCS Spring Clips...
Amazon Amazon
Old Apr 28, 2020 | 10:38 AM
JUKE179r's Avatar
@redrover75 ... the brake vacuum line is 9mm and I think (?) the SAI tubes are 3mm.
Originally Posted by cvhyatt
WMYCONGCONG 155 PCS Spring Clips... https://www.amazon.com/dp/B078GCPMQH...p_mob_ap_share
That is a nice kit.
Old Apr 28, 2020 | 02:49 PM
matt3502's Avatar
CVHyatt- Which lines did you put these spring clamps on? I'm very intrigued by your solution!
Old Apr 28, 2020 | 07:21 PM
cvhyatt's Avatar
My problem was with my SAI system so I addd spring clips on the end of each SAI vacuum tube.
Old Apr 28, 2020 | 07:49 PM
Dave03S's Avatar
Don't forget about the one on the throttle body! Great work!! I've been using tiny zip ties with mixed results but this is a better way.
Ben Matheson
Apr 11, 2019 10:47 AM
wrongway1
May 24, 2014 03:09 PM
willrok13
Jan 4, 2013 12:27 AM
mr_boondoggle
Jan 19, 2009 02:15 PM
Lnghrn Disco
Jun 6, 2007 10:26 AM
