What is the black plastic soda can shaped thing by the said pump?
Old Apr 10, 2019 | 10:23 PM
Ben Matheson's Avatar
Default What is the black plastic soda can shaped thing by the said pump?
? Has 2 vacuum lines one on each side
Old Apr 10, 2019 | 10:31 PM
ahab's Avatar
Vacuum reservoir
Edit:
Old Apr 10, 2019 | 10:39 PM
Thanks. Was wondering if that might be an easier way to to suck in some seafoam than messing with the brake booster line.
Old Apr 10, 2019 | 10:48 PM
ahab's Avatar
Anything is better than messing with brittle plastic. I've not done the Seafoam thing on a Rover yet but any vacuum line will work on a vehicle that has a single throttle plate. Vacuum is vacuum. Some ports might be better than others from a "drown the engine perspective", but as long as it gets into the intake stream it will be metered into all cylinders evenly. The brake booster line does have the advantage of not triggering an SAI code that you might get from the vac reservoir tubing. If you've done a recent PCV mod that might be a workable approach too. All of these are on the engine side of the MAF tho so I would think mixture related codes could be an issue.
Old Apr 11, 2019 | 01:58 AM
JUKE179r's Avatar
@Ben Matheson ... try this for your Disco... LAND ROVER CLUB VI - Seafoam Induction Cleaning
One caveat from the instructions, I'd add the Seafoam to the tank FIRST then do the induction method.
Old Apr 11, 2019 | 10:47 AM
The motor was rebuilt last year so everything should be pretty clean. I just want smoke to look for exhaust leaks lol
tomw3115
May 6, 2019 08:52 AM
ctang101
Nov 7, 2017 08:38 AM
wrongway1
May 24, 2014 03:09 PM
dgilaon4
Jul 28, 2009 08:59 PM
