Valve Cover Gasket
Old Dec 17, 2007 | 08:47 PM
Boyd's Avatar
4th Gear
Default RE: Valve Cover Gasket
Mike,
What about the in take manifold gasket/seal does this not need replacing?
What seals would you suggest? new rubber type?
What is the torque setting for the manifold bolts and the vavle cover bolts.
Cheers Boyd
Old Dec 17, 2007 | 10:43 PM
mordor110's Avatar
ORIGINAL: Disco Mike
You need to loosen and or remove all the bolts from the intake manifold, just the top not the bottom. Once you have done that you can move the top half around or remove it, do the vc gaskets and reinstall.
Mike
Mike,
There's not a gasket sealing the two halves of the upper & lower intake manifold that you should be concerned about & inspect before reusingwhen seperating the upper & lower?
Old Dec 18, 2007 | 11:30 AM
You should replace the intake manifold gasket whenever you are pulling the top end of the engine down, it has a tendency to become oil soaked with time.
I don't have the torque specs, sorry.
Old Sep 21, 2008 | 07:22 PM
NiteTrain's Avatar
is this the intake manifold gasket that needs to be replaced? can you use O2 safe RTV sealant instead of the gasket?
http://www.roverparts.com/Parts/ERR6621.cfm
Old Sep 22, 2008 | 03:15 AM
NiteTrain's Avatar
anybody else think that having only 4 bolts might be the reason these valve covers leak?
herblatham
Jun 28, 2008 09:09 PM
discomaine21
Jan 6, 2008 10:58 PM
humroot
Nov 4, 2007 12:05 PM
wease206
Mar 1, 2007 07:38 PM
