Valve cover seating
I'm not sure if it is a big deal but what I found is that the reason its doing that is because it isn't lined up correctly. I lined up the front outside corner by pushing it in with a screw driver and tightened it just enough to hold it. Then stuck a screw driver in a whole on the other side and pried it so that the other whole on that side was perfectly lined up and sitting right. Not sure how much sense that makes so let me know if you need clarification.
Blakesrover
02-21-2013 01:45 AM
