Valve cover seating
Old May 22, 2019 | 11:23 AM
Brandon318's Avatar
Default Valve cover seating
Hey all,
Installing the valve covers and it looks like the gasket is ever so slightly imperfect, making the lip sort of protrude a bit. Like, that little groove the cover sits in is poking out in places a little more than I would’ve expected. Big deal?
Old May 22, 2019 | 12:07 PM
Old Bertha's Avatar
I'm not sure if it is a big deal but what I found is that the reason its doing that is because it isn't lined up correctly. I lined up the front outside corner by pushing it in with a screw driver and tightened it just enough to hold it. Then stuck a screw driver in a whole on the other side and pried it so that the other whole on that side was perfectly lined up and sitting right. Not sure how much sense that makes so let me know if you need clarification.
Old May 23, 2019 | 06:03 AM
shanechevelle's Avatar
Did you put the 4 little spacers back in the gasket before putting the cover on?
Old May 23, 2019 | 07:30 AM
CollieRover's Avatar
Get molded gaskets. Way better.
Old May 23, 2019 | 07:38 AM
Sandman614's Avatar
Do you have a part number for those?
Old May 23, 2019 | 08:07 AM
OverRover's Avatar
Originally Posted by sandman614
do you have a part number for those?
FEL-PRO: VS50789R
or
MAHLE: VS50513
Old May 23, 2019 | 09:30 AM
Brandon318's Avatar
I did indeed. Welp, we shall see. I buttoned it all back up.
Old May 23, 2019 | 09:52 AM
Maybe it won’t leak, but those floppy crappie gaskets SUCK to install. Autozone has the fel-pros
Old May 24, 2019 | 07:01 AM
Sandman614's Avatar
FEL-PRO: VS50789R
or
MAHLE: VS50513
Thanks, I just ordered the Fel-Pro ones, I will be doing this at some point.
MellBelle
Dec 9, 2022 07:51 AM
Rgrimes007
Feb 22, 2022 08:18 AM
thensley723
Mar 17, 2017 08:11 AM
Jeff Blake
Nov 22, 2016 02:32 AM
Blakesrover
Feb 21, 2013 01:45 AM
