Valve Sticking??
Old Jan 20, 2009 | 07:32 PM
Default RE: Valve Sticking??
But did you change the plugs too?
New plug wires will not have any effect with fouled plugs.
Old Jan 21, 2009 | 04:54 PM
sdsilvere38's Avatar
I only changed the fouled plug since all the other Champions were good.
Old Jan 21, 2009 | 05:00 PM
Ok, so new wires, new plugs and same problem on the same cyclinder?
Old Jan 22, 2009 | 10:12 AM
ORIGINAL: sdsilvere38
Well, just got back from the Rover Indy and he said that all cylinders are getting perfect compression but the #5 cylinder is putting a little bit of oil on the plug causing a misfire. He said it could be a valve sticking. Can this be fixed without a rebuild? Will the ATF "oil" change clear this up?
What were the compression numbers or at least how far off is #5?
Has a leak down test been performed?
Don't do anything to the engine till we can get more information.
I would also suggest you send me your tele number so we can get more specific.
jgalderman
Jul 24, 2011 05:52 PM
louianquin
Freelander
Jun 11, 2008 02:53 PM
DJKizzyKat
Freelander
May 14, 2007 05:26 AM
drhunter
Apr 25, 2007 12:15 PM
merrick
Jan 15, 2007 08:56 PM
