Valve Stuck ... Damaged Piston ... Options?
Old Jul 12, 2019 | 12:07 PM
abran's Avatar
I would turn the motor manually to feel if it turns ok and see if that piston still goes all the way to the top. If it does, chances are the rod is fine.
But, at a minimum I would drop the oil pan and have a look from the bottom. And, while the pan is off, that front cover could use a rebuilding!
Old Jul 14, 2019 | 12:35 AM
shanechevelle's Avatar
Originally Posted by Motorhead1
measure the piston deck height, if the rod is bent the piston won't come up as high as the others.
This.
Clean that cylinder and look for cracks.
Swap, lap the valve or buy a head at the upullit. Put it back together, have fun. By the looks that was minor.
Bal D Correa
Sep 16, 2019 02:09 PM
tailchaser0527
May 5, 2009 06:10 PM
wbstyles
Dec 31, 2008 09:02 AM
wbstyles
Dec 31, 2008 07:49 AM
JerrodSteph
Nov 18, 2008 02:23 PM
