Variable voltage readings on both downstream O2 sensors
Old Nov 29, 2025 | 03:19 PM
SouthByWest's Avatar
Default Variable voltage readings on both downstream O2 sensors
I have a code for an aging lambda sensor.
I checked the voltage readings for all four sensors. The upstream ones are functioning correctly, moving between high and low readings with regularity.
The downstream sensors are also both showing widely variable readings. My understanding is that their readings are supposed to be pretty constant, around 0.45 volts or so.
I’d appreciate suggestions as to how to how to go about diagnosing this. I’ll be smoke testing the exhaust for leaks next week.
Old Nov 29, 2025 | 04:21 PM
Extinct's Avatar
Start by swapping the one with the code left to right.
11chuck
Mar 7, 2022 06:28 PM
cobbcj7
Aug 18, 2016 01:07 PM
philwarner
Jun 17, 2015 10:27 AM
philwarner
May 25, 2015 03:02 PM
ArmyKen
Dec 17, 2010 01:52 PM
