In vehicle battery charger
Old Sep 14, 2021 | 02:12 PM
rikkd's Avatar
Default In vehicle battery charger
Has anyone installed a small battery/float charger on the vehicle? I was thinking of doing this as my vehicle may sit for a few days and I'd like to run the radio, fans, and lights when working on it, while it may not drain the battery much, the peace of mind that I won't kill my new battery (I have a tendency to kill batteries) would be nice (assuming I do it right and don't burn the truck down). I was also thinking of adding a shore power plug somewhere on the vehicle, and adding a fake plug in hybrid badge next to the V8 badge.
Old Sep 14, 2021 | 05:12 PM
Harvlr's Avatar
I keep a battery tender on my motorcycle. I’m not sure if you should try to run systems with it on though (might overtax it?)
Old Sep 14, 2021 | 05:29 PM
andino's Avatar
I have a battery tender/charger lead hooked up to my starter battery. When I'm working on it for extended periods, I can plug in my charger to keep it topped off. I have the same style lead setup on my second car which only gets driven on weekends so I can use one charger for all my vehicles.
Old Sep 14, 2021 | 06:55 PM
Extinct's Avatar
I have the solar battery charger from Harbor Freight on mine, works for exactly what you are looking for. I leave it in the windshield on the passenger side.
Old Sep 15, 2021 | 07:44 PM
rikkd's Avatar
I do that when I park/work on it for more than 3-4 days
Old Sep 16, 2021 | 10:34 AM
WaltNYC's Avatar
I just wired the socket in the cargo area directly to the battery and bought a solar panel to trickle charge it.
Old Sep 16, 2021 | 11:29 AM
Sean Maginness's Avatar
I wired a pigtail connection to my battery and then use either a solar charger or plug-in charger to keep the battery happy. At peak Covid my D2 sat for weeks at a time, a solar charger was great. I also keep a dashcam running all of the time with a low voltage cut-off switch. So I like to keep the battery above that cut-off voltage for the camera to keep running.
Now I think about it, at peak Covid all of our cars were on battery chargers.
Rufflyer
Aug 22, 2016 09:25 PM
Rufflyer
Dec 21, 2014 09:26 PM
jmason
Apr 5, 2013 12:54 AM
nahtanoj
Nov 4, 2011 09:26 PM
yarddawg
Jan 15, 2008 07:40 PM
