Ventilation fan is squeaking. Replace it or lube it?
Old Dec 8, 2013 | 09:16 PM
bcolins's Avatar
Default Ventilation fan is squeaking. Replace it or lube it?
My heating and A/C ventilation fan has started squeaking. I've had enough vehicles now that I know this can sometimes be fixed with a spray of WD40 or similar,.....and sometimes can only be fixed by replacing the squirrel cage.
Any way to lube this one?
Brian in Austin
Old Dec 9, 2013 | 03:44 AM
While you can, it will only be a short term fix usually. Getting to it to lube is about same labor as replacing it.
Old Dec 9, 2013 | 09:43 AM
Bob Loblaw's Avatar
I followed this post:
https://landroverforums.com/forum/di...llation-55530/
and my fan has been quiet for months now. Yes, it's only a temporary fix, but a new blower motor seems expensive.
Old Dec 9, 2013 | 09:51 AM
dr. mordo's Avatar
I lubed mine a year ago and it's been quiet since.
Old Dec 9, 2013 | 10:59 AM
drowssap's Avatar
3 screws and the motor drops down for lubing
Old Dec 9, 2013 | 11:13 AM
SuperSport's Avatar
Use my thread posted above. I did mine the day that was posted. It was Jan 2nd of this year. My fan was quite loud on turns due to dry bearings. It has not made a peep since. I don't even know what the fans cost, but the lube job was super easy and didn't take too long (I'm guessing around an hour). If I can hold off the cost for a few years, I'm happy.
Scharfire
Jul 6, 2021 02:59 PM
paulfromperu
Apr 19, 2009 10:14 PM
Luv2Disco
Nov 16, 2008 10:46 PM
targotsi
Sep 23, 2008 08:02 AM
jmt
Jan 14, 2008 05:01 PM
