very cold start
Old Dec 22, 2008 | 09:26 AM
roverboy's Avatar
Default very cold start
woke up this morning 30 degrees in Houston,Tx car turned over one start but was hard yesterday was 75 degrees so as I warm up the car check engine throws a light go to auto zone code p0125 did the research on forum and found out what it was well I am not getting bad gas milage or is sge running richI rode arond Houston all day went 135 miles and used alittle over a quarter tank of gas temp gauge is working fine so auto zone reset the computer and found no codes usaully when you reset the engine light the code is still stored could be of very unsual Tx weather
Old Dec 22, 2008 | 09:59 AM
Default RE: very cold start
Your coolant temp sensor is not showing the proper temp and this cause your ECU to stay in it's cold start up mode called "Open Loop".
Old Dec 22, 2008 | 10:43 AM
NiteTrain's Avatar
if the ECU is getting a false low reading from the coolant temp sensor and staying in cold start up mode isnt that 'open loop'?
Old Dec 22, 2008 | 10:53 AM
roverboy's Avatar
thanks alot disco mike
Old Dec 22, 2008 | 01:58 PM
ORIGINAL: NiteTrain
Thanks for catching that, second goof in a couple days.
GURU06
Jan 12, 2013 01:13 AM
foamwizards
Sep 16, 2011 05:28 AM
MikeThomas
May 10, 2011 10:21 AM
JimScream
Nov 29, 2008 02:09 PM
pureanal
Jul 11, 2006 09:29 PM
