Vibration
Old May 14, 2009 | 09:01 AM
lxrules's Avatar
5th Gear
Question Vibration
I have an '01 Disco II. Recently a vibration has developed while accelerating from a stop. Having searched the forum, probable causes could be the u-joints, unbalanced drive shaft, and or a CV joint along with other drive line maladies. Where should I start? I don't want to guess and replace a bunch of parts hoping to discover the problem.
Thanks,
Scott
Old May 14, 2009 | 10:04 AM
Go count how many grease fitting are on your front drive shaft, should be 3, if not quit driving it till we talk.
Old May 14, 2009 | 10:53 AM
lxrules's Avatar
5th Gear
Already deadlined the truck pending diagnoses. I will let you know. Thanks!!
Old May 14, 2009 | 08:16 PM
lxrules's Avatar
5th Gear
No grease fittings, though I noticed an obvious broken bearing on the u joint closest to the transfer case. Where do I go from here?
Kiwi Mike
Mar 2, 2006 07:32 AM
kennims
Jan 22, 2005 08:22 AM
Greyfoxvt
Jan 9, 2005 09:04 AM
berg7171
Dec 27, 2004 06:35 PM
Benhamtroll
Dec 13, 2004 04:35 PM
