vibration at 2500 rpms
Old Feb 9, 2006 | 04:27 PM
JRdisco1's Avatar
Default vibration at 2500 rpms
Sorry I know I'm postin alot. I just now noticed a mild vibration at 2500rpms. It seems a bit sluggish too. I was guessin prolly a sensor of some type? any ideas?
Old Feb 9, 2006 | 05:32 PM
JRdisco1's Avatar
Default RE: vibration at 2500 rpms
I might end up answering my own question! It may help to also know it is kinda slow cranking. So now I'm wonderin if its not my plugs and or wires?
Old Feb 10, 2006 | 10:25 AM
Landzu's Avatar
Is it slow to turn over , or turns over fine slow to start ?
Old Feb 10, 2006 | 12:38 PM
JRdisco1's Avatar
Turns over good. It just takes it a second longer than usual. It seems like it only vibrates around 2250-2500 RPMS once you are over or under it is fine? I tried it in park and it still does it...
Old Feb 11, 2006 | 10:29 AM
Landzu's Avatar
With out a CEL on I would first check the bolt on the harmonic balancer.
With that good then check the fuel filter.
Now you said some thing about spark plugs & wires, if the plugs are over
10,000 miles go ahead and change them if not you can just clean them.
If the wires have more than 30,000 miles change them.
Also to make sure that you are not grounding out with the spark plug wires
get some dielectric grease. ( get it at a Auto Zone small tube $ 3 )
I have used dielectric grease on every electric connection and my Disco
feels like it runs better.
LOL Mike
Old Feb 12, 2006 | 01:36 PM
Landzu's Avatar
Check motor mounts also.
golf97
Aug 23, 2012 03:22 PM
gwhiz101
Aug 29, 2010 08:48 PM
free_kid
13
Feb 3, 2010 12:56 PM
vik
Apr 14, 2008 03:40 PM
tads
Jun 6, 2007 01:20 PM
