vibration!
#21
so you are saying that instead of fighting with the nuts holding the flange to the park brake drum you took the u joint apart while still on the truck? I will have to keep this in mind, still seems like a lot of work for a problem that I am unable to pinpoint, but then again maybe I need to go ahead and just do this to isolate where the problem is. it is very tough to do any jobs that take more than a few hours because I have a family of 4 in an apartment and this is our only vehicle.
#22
It worked preaty well for me. Spray some kind of parts loosening fluid (wd-40 or something better) on the u-joint a few days ahead of the job. Soak it well and soak the caps well. It will really help the caps come out. I hope i don't lead you astray but I was the guinea pig for this. Just hope it works as well for you as it did for me.
99, accelerate, acceleration, brake, discovery, drive, driveshaft, land, parking, realign, rover, shaft, splines, vibratioin, vibration
