Vibration at 40mph
Old Apr 13, 2016 | 05:25 PM
me6067's Avatar
Default Vibration at 40mph
Just looking for a little help, I have a vibration that starts at around 40mph and goes away as I speed up. I have already replaced both my front and rear drive shaft with the one offered by lucky8 about a year ago, have always greased them and only have about 6k miles on them.
Could this be tires they are relatively new ko2's...
Old Apr 14, 2016 | 11:57 AM
Joe!'s Avatar
Have your tires balanced. My 03 had the vibration around 30-35 and my dads had it around 40. I needed a new driveshaft and his was tires not balanced. Since you have a new driveshaft I would get the tires balanced first
Old Apr 16, 2016 | 02:01 AM
jfall's Avatar
You had better lube the drive shafts.
One of those could be dry from lube simply gone.
I had such a problem.
After I pumped in lube / grease the problem went away.
And I drove many thousands of miles afterward.
https://www.flickr.com/photos/76579732@N07/
Bad drive shaft is sort of like a humming vibration.
If your wobble or vibration is affected by braking then it is probably a tire out of balance.
You could move tires from front to back and see if the vibration changes locations.
Bassmaster
Mar 13, 2014 10:28 AM
flygirl92
Jul 7, 2011 09:00 AM
dqualter
Jan 8, 2011 12:28 PM
justjack
Nov 28, 2008 02:15 PM
JerrodSteph
Sep 21, 2008 11:52 AM
