Vibration no codes
Old Mar 24, 2008 | 11:15 AM
dlkk's Avatar
Default Vibration no codes
First let me say thank you to you guys thay have helped me out over the years.
Now, I've got a 98 disco w/ 198k and have always kept it tuned and clean. I've got a vibration that feels exactly like a u-joint beginning to go though when I ran some injector cleaner through it smoothed out the ride. Still a little vibration though about 60%A better. I don't have any codes so does anyone have ant ideas where to start? Injectors? U-joints ect...?
Thanks,
dave k
Old Mar 24, 2008 | 12:54 PM
okdiscoguy's Avatar
Default RE: Vibration no codes
do you feel it at a certain RPM, and can you feel it just revving it up in neutral?
Old Mar 24, 2008 | 01:04 PM
dlkk's Avatar
Vibration is at its worst during acceleration and speeds between 10 and 30. Higher the spped the more it smooths out. Cold idle bounces around a little though warm its smoooth.
dave
Old Mar 24, 2008 | 01:16 PM
dlkk's Avatar
okdiscoguy.i just went out and reved it up in the driveway and it does seem to vibrate a little around 2000rpm. Its less noticeable just reving it up though it seems probable that its the same vibration I feel under acceleration. Plugs are ok.
dave
Old Mar 24, 2008 | 01:28 PM
okdiscoguy's Avatar
I get a vibration around 2500 RPM. I think it is a bad exhaust valve. Sometimes it is ok, but others I can really feel it. Just like yours, the harder I push, the worse it is.
Old Mar 24, 2008 | 01:39 PM
dlkk's Avatar
I had new heads put on around 150k so i don't think its valves, or i at least hope not. about the only thing i haven't replaced over the last 8 years are the injectors.
Old Mar 24, 2008 | 02:00 PM
You need to decide if it is drive train or an engine vibration.
Drive train, has to be tires, could use all new u-joints.
If it is engine related, first check and see if you left motor mount is broken.
How long since it has had a major tune up including wires? What octane gas are you running and was was the engine last de-carboned?
Old Mar 25, 2008 | 01:33 PM
dlkk's Avatar
92 octane, tuned last summer, seafoamed about two years ago. I baught 4 u-joints and I'll have the motor mount checked. start with the cheap first. I'll let you what happens.
dave
Old Mar 25, 2008 | 02:05 PM
Doesn't always work, certain not the cheapest way to go. Still need to have you decide if it is drive train or engine, do you have any codes??
Old Mar 25, 2008 | 04:16 PM
dlkk's Avatar
I can't tell if its drive train or engine. no codes and runs pretty smooth for 180k. vibration is at 1500 to 2000rpms through each gear and not specific speeds.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
