Vibration under load
Old Mar 4, 2009 | 08:10 PM
kruth's Avatar
Default Vibration under load
Hi Everyone,
I have a 2000 Disco II with 120,000 miles. I replaced the u-joints about a year ago before reading this forum and did not put the greasable u-joints in it. This past week I started getting a weird vibration with heavy acceleration from a stop. If i accelerate heavily at seventy everything is smooth, however at sixty it shakes; I think this just has to do with how much force there is on the driveline and transmission. Do you think I really need to have the front driveshaft rebuilt again with the new u-joints after one year or could it be something else?
Thanks for all of your help
Old Mar 4, 2009 | 08:20 PM
discodefender's Avatar
I would say yes and did you clock them?
Old Mar 4, 2009 | 08:55 PM
DO NOT wait on this.
YES the new u-joints could have failed after only a year, essecially if they were cheap ones.
Old Mar 4, 2009 | 09:52 PM
khuds308's Avatar
yes you need new U-joints.
Old Mar 4, 2009 | 11:18 PM
kruth's Avatar
Yeah, that's what I was afraid of. I'll be on it by Friday. Should I go ahead and re-do the rear too? I didn't maintanence it when I did the front.
Also, while I'm at it I haven't serviced the tranny since I've owned my disco and I bought it with 100,000 miles, should I look at having it serviced? I live in a fraternity house so I'm kind of lacking any major tools beyond a basic socket set and wrenches. Even my pump to change the fluids is at home and I would like to change out the differential fluid as well. So if anyone knows of a good machine shop to have my driveshaft rebuilt and another shop to have the diff and tranny serviced in Atlanta the help would be greatly appreciated.
Thanks Again
Old Mar 5, 2009 | 07:19 AM
kruth's Avatar
I have a new symptom, when I posted before I had not revved the engine in neutral. Well, I also have the vibration starting at about 2500-3500 RPM in neutral and I am not throwing any codes. This means it must be an engine problem right? I changed plugs and wires about 10,000 miles ago and I always run Premium gas. I'm kind of stumped on this one. Is there a possibiltiy of having too much build-up in my catalylitic converter?
Old Mar 5, 2009 | 10:13 AM
Send me your tele number and I'll call you ASAP.
Old Mar 5, 2009 | 03:41 PM
rrhyne's Avatar
Mike, can you report back here what you went through with him? I had the vibration under heavy load with5 people over 160 pounds and 150-200 pounds of luggage. I have a brand new grease able shaft though.
I just replaced springs and shocks and I suspect the vibe has gone away, as a my vibration at 70-75 is gone now.
robertmirwin
Oct 8, 2013 12:56 PM
Disco203
Aug 19, 2013 09:48 AM
formel3
Aug 7, 2013 03:33 PM
teddyz
Aug 2, 2013 11:56 AM
jcostello
Feb 20, 2007 07:18 PM
