Vibrations, Solved
Old Jan 29, 2009 | 06:49 PM
rrhyne's Avatar
Default Vibrations, Solved
If you are experiencing a vibration that happens only in certain speed ranges, say from 45 to 50 or 70 to 75, a very likely culprit is unbalanced tires. I've had a vibration from 45 to 50mph for a couple of weeks now, and it started to get progressively worse to the point where it was wobbling the steering wheel. I just had my tires balanced and the problem disappeared and it only cost me about 20-30 bucks.
I didn't have to pull my drive shaft, or take it to a driveline shop... just a run of the mill used tire shop.
Old Jan 29, 2009 | 07:44 PM
AK Rover's Avatar
Default RE: Vibrations, Solved
Thanks for the tip. It's amazing how many problems tires can cause that most people never think about.
Old Jan 29, 2009 | 07:46 PM
rrhyne's Avatar
That's the second time something with tires has fixed vibrations with me. The first was 70-75mph, I popped the right front and replaced it, and that vibration went away.
KenR
Feb 12, 2013 06:04 PM
stevenramsey
Apr 16, 2007 12:36 PM
blackdisco2001
Mar 10, 2007 02:14 PM
dewhorse
Mar 27, 2006 11:14 AM
Bene
Apr 27, 2005 12:56 AM
