Vin Number indicate options?
Old Jul 28, 2009 | 12:07 AM
ljdiscovery's Avatar
Default Vin Number indicate options?
Is there a source to check the original options on a Discovery using the VIN? If so, what is the method? I am now looking at a 2001 Discovery light on options but the price is good, only 75k miles, dealer maintained, new brakes, recent 60 mile service, everything works, only needs the drive shaft upgrade. No sunroofs, now ACE, 16 inch rims vs. 18 inchers. Thanks Phil
Old Jul 28, 2009 | 07:53 AM
jycsalas's Avatar
PM me your vin and I will enter it in the parts catalog and let you know what I find. It is right on with telling me what my 03 came with.
Old Jul 28, 2009 | 08:17 AM
You are looking at a base "S" model, what are they asking for it?
Old Jul 28, 2009 | 08:20 AM
antichrist's Avatar
Plug in the VIN here http://www.clifton.nl/index.html?calvin.html
Old Jul 28, 2009 | 08:25 AM
That site won't give you any options based on the vin. The only way to get any options is to ask a dealer to run the vin and get a print out from the factory, problem is, most dealers won't/can't do this because you are not the current owner.
Old Jul 28, 2009 | 08:16 PM
so I checked out the discovery. Overall it is in pretty good shape. It does have some paint issues, it is fading on the hood, looks like the clear coat is going. It also has some clear coat peeling on the edge of the roof above the windshield. It also has a cracked windshield. Inside it looks good, vinyl, not leather, sagging headliner, surprise.....some wax on the back of the rear seats from surfboards. It looks like it just had a tuneup and brakes. Black magnacor wires, fluids topped off, clean oil and clean air filter. Rotors looked like they were put on yesterday. New LTX Michelins on the front, 50% Michelins on the rear, crossterrains as I recall. Brand new goodyear spare. Transfer case worked without a hitch. Cruise, AC, radio and all other electronics worked. Only thing it appears to need is an upgraded front drive shaft. Surprisingly dry under the truck. Priced very competively. Should I hold out for a better equipped model ie leather sunroofs, ACE, upgraded stereo, fog lights, etc. or should I go with a great price on a truck that needs a little detailing but looks to be in tip top mechanical shape.......ideas...thanks phil
Old Jul 29, 2009 | 08:38 AM
Needs a lot of work, unless you can buy it for under $2000, pass on it.
Old Jul 29, 2009 | 09:30 AM
Got an email from the first owner last night. Not confirmed yet, but according to him, the truck developed a head gasket problem at 38k miles. Under warranty, the dealer Land Rover Mira Mar replaced the block as part of the fix. Sounds a little odd to me. If it was just a head gasket, why not just change the head gasket.....Anyway, he supposedly sent all records to the current owner, time will tell. He is looking for more than $2000 but the price is not out sight. Mechanically the truck is appealing, options wise, I sure wish it was a bit more upgraded. Phil
kinden
Jan 15, 2010 03:23 AM
ticex
Aug 8, 2009 05:52 PM
def90rich
Defender
Feb 21, 2008 01:22 PM
DrLivingston
Nov 23, 2007 12:46 AM
ScottJ
Oct 2, 2007 02:19 PM
