Viscious wind noise ( problem fixed )
Old May 5, 2011 | 09:12 AM
DiscoveryHouston's Avatar
Default Viscious wind noise ( problem fixed )
Soooo, after trying everyone ideas on fixing the problem I had with my wind issue. I decided to take the door panel off and have a look internally. What I discovered is that the 2 bolts that attach the window frame down at the bottom of the door inside the door panel had come loose and (1) was missing. I tightend one & replace the other and now the frame is solid. The only thing that was holding the frame somewhat sturdy were the (2) adjusting hex head screws up top. Glad. I didnt fork over the $100 + dollar to AB for all new rubber, seals, etc...Home depot and a $1.49 later and we are good as new.
Old May 5, 2011 | 09:14 AM
jafir's Avatar
awesome! thanks for the response as to the solution. It may help us other users if, in the future, you put the solution with your original problem post, just to make it easier to read.
twanmedley
Jan 3, 2008 11:55 AM
ryant06
Dec 27, 2007 03:29 PM
discoken
Aug 28, 2007 10:04 AM
cheatham25
Feb 16, 2007 11:14 AM
cmitty
Dec 20, 2005 01:36 AM
