Walked cam bearing (lifter ate right through it)
Old Aug 8, 2017 | 05:57 PM
Blacktt3z's Avatar
Default Walked cam bearing (lifter ate right through it)
So I'm ordering new finished cam bearings and the Kent performance cam from turner engineer. My question is where can I find the tool to press in and remove the bearings?
Old Aug 8, 2017 | 09:04 PM
No Doubt's Avatar
Don't you have to remove the cam from the top to change those bearings because they are 1 piece instead of 2 half-pieces like the rod bearings??
Old Aug 8, 2017 | 09:05 PM
No Doubt's Avatar
For sure you will want to replace your rod bearings (easy!) from below now that you've got the oil pan off.
Old Aug 9, 2017 | 01:14 PM
Davis31052's Avatar
Here is one tool to install cam bearings. Your local auto parts chain store, O'reilly, Auto Zone or Advanced will most likely rent you one.
Lisle Corporation
94svt50
Aug 10, 2019 06:43 PM
lrjon
Apr 17, 2016 10:44 PM
abran
Dec 18, 2015 09:05 AM
lrjon
Dec 5, 2015 06:39 PM
tomfraser
Jan 24, 2009 07:54 PM
