Warn x8000i
Old Oct 27, 2007 | 09:49 PM
Kraftyz51's Avatar
Default Warn x8000i
I put on the ARB on my Disco II and I was wondering has anyone ever tried to mount a Warn x8000i in a Disco 2 ARB? The 8000i has the integrated solenoid in the housing. I have the fairly new winch that I took off my old truck just sitting in the garage. I know an 8000i is said to not have enough power but I think with enough ****** blocks it will be. Any input you guys have would be much appreciated.
Chris
Old Oct 27, 2007 | 10:12 PM
ajh's Avatar
ajh
Default RE: Warn x8000i
Take a look at http://www.discoweb.org/joshuaw/arbbumper/index.htm which shows how you can go about mounting various feet-down winches onto an ARB. I'll be doing something similar to mine, along with additional trimming along the bottom, moving the fairlead upwards to be able to use a hawse, etc.
Old Oct 28, 2007 | 09:18 AM
The 8000 is just slightly light, but will handle most Disco pulls easily. For the hard pulls a block will make that little extra difference. Make sure you run a good, pretty new, stronger then average battery so your winch will have as much help as possible. I run dual Yellow Tops with my 9500 Warn HSI and can pull till hell freezes over with no problem.
Good luck.
faturbo
Nov 5, 2009 01:47 PM
undertaker
Apr 28, 2009 05:34 AM
b18cx
Sep 28, 2008 08:10 PM
Kraftyz51
Nov 1, 2007 07:30 PM
wedagingers
Apr 4, 2006 05:52 PM
