Adding Grease to Hubs?
Old Oct 28, 2007 | 08:56 AM
ajh's Avatar
ajh
Default Adding Grease to Hubs?
Any good way to add grease to the sealed hubs on the disco II? I know the last mechanic blew out some of the grease in one hub, can I replace it with other high-pressure grease?
Old Oct 28, 2007 | 10:00 AM
Default RE: Adding Grease to Hubs?
For all intents and purposes, the hubs are no servicable.
Old Oct 28, 2007 | 10:31 AM
ajh's Avatar
ajh
Sorry I should have phrased that better. I don't know about rebuilding hubs or packing bearings. If I fill the hub with new grease is it going to cause any issues? I'm thinking hydraulic pressure issues like say if you over-filled a diff etc. I'm guessing no. If it's ok then adding some to the abs sensor hole to replace what the mechanic blew out with compressed air would hopefully prevent premature failure of that hub. I realize this isn't the common case, but I witnessed him blow it out.
Old Oct 28, 2007 | 10:38 AM
Won't help a thing and can cause the excess grease to heat up and works it's way out onto your brakes.
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
Tvdmtac
Oct 15, 2007 03:25 PM
ajh
Aug 22, 2007 05:30 PM
alex of minnesota
May 13, 2007 07:54 AM
