Warning light
SLS sounds likely. Try running the truck and pressing the SLS button on the dash to raise the rear end, then driving for a bit until it resets to normal ride height. If you're in a cold weather area the system may have leaked down to the point where it's causing an error. Either that or there's a fault somewhere and the system is not able to adjust itself any more.
Self-levelling suspension -
AMBER (if fitted)
Illuminates briefly as a bulb and
system check when the starter switch is
turned to position ’II’ and then extinguishes.
If the remote handset is operated:
The light flashes continually while the rear of
the vehicle is being lowered, or raised.
If the light illuminates constantly, this
indicates a fault with the self-levelling
suspension and you should seek qualified
assistance.
AMBER (if fitted)
assistance.
cipher982
11-09-2019 11:22 AM
mvjimenez
06-12-2010 10:25 AM
