washer fluid to rear window not working
Old Feb 8, 2014 | 03:22 PM
rodcrafter's Avatar
Thanks for the feed back will go from here...Lee
Old Apr 4, 2017 | 02:19 AM
Paulo NZ's Avatar
Mine was an easy fix, there is a non-return valve in the rear door just before it reaches the spray nozzle. It was blocked. All I had to do was remove the plastic that is just clipped on at the top of the door and replace. Unfortunately, I had spent hours tracing the fault from the water bottle. I replaced it with a streight joiner - didn't worry about the non-return valve.
Old Apr 4, 2017 | 10:05 AM
shanechevelle's Avatar
Normal fix for a washer nozzle...
Remove hose at washer nozzle, spray compressed air backwards through nozzle, reattach hose.
Spray
Old Apr 4, 2017 | 11:35 AM
DrDash's Avatar
Spray
I need to try this today lol. When I got my car all were working, then front stopped, then headlights stopped and rear continued working. Now all of a sudden front left started working again but nothing else LOL.. Today compressed air will make a debut, considering I purchased this from Florida I was thinking maybe they used water and it froze when it got cold here in NY
Thanks
fRANKIE
Old Nov 30, 2022 | 03:50 PM
oztayls's Avatar
4th Gear
I'm having an issue where the rear window washer is only dripping water from the nozzle on the wiper. My car failed its annual registration check because of it. Where is the rear window washer pump located? I've looked everywhere but just can't find it!
Old Dec 1, 2022 | 03:00 PM
gecko951's Avatar
Both washer pumps are mounted on the windshield washer fluid resevoir; number 5 in the diagram.
https://www.roversnorth.com/category...eadlamp_washer
Old Dec 1, 2022 | 03:06 PM
oztayls's Avatar
4th Gear
OK many thanks! Cheers.
Old Jul 21, 2025 | 02:02 PM
navkol's Avatar
Where is the washer pump fuse located?
twoxred
Oct 4, 2021 07:07 AM
krazzz
Jan 15, 2010 07:17 AM
VikingDiesel
Mar 11, 2009 07:20 PM
rgreenwell8962
Jul 2, 2007 10:09 AM
dailyuser
Jul 27, 2005 09:32 PM
